Thank you! That took care of the issue. You have saved me hours of frustration. I appreciate your very very VERY fast response. (FYI, your email signature ended up on GeoNet, not sure if you want that personal information out on the interwebs.)
I spoke too soon. It worked once, and then not again. I also took Petronila Mandeno's advice (below) and removed all other TIFFs from the map document, but it is still losing its position when I select "Update Georeferencing." Going to have to stop for the day before I pull out my own hair.
I've had this issue in 10.6 and 10.7 so it's been frustrating. In ArcMap Options > Raster > Raster Dataset the box for "Use world file to define..." was already unchecked. I tried your suggestion of NOT building pyramids and it worked. Thanks!
Just some more two cents: what seems to work best for me is to load only one image at a time. If I have more than one image to geo-reference in the data frame, then which ever one I just to geo-reference goes wonky when I try to update. But if I only have one image to geo-reference in the data frame, all goes well.
I know, that seems totally random, but it's what I've found works for my system (because rectifying takes way way too long). I hope that helps someone.
I am having the same problem with my larger rasters.tiff images with 10.5
I have tried the above mentioned solutions, currently trying the Rectify option - which is not optimal for me since it takes longer than I need it to.
I would love a solution ESRI (and please do not tell me to move to Pro).
Upon further testing and after conferring with some other nearby agencies that use GIS to georeference plan sheets, we determined that part of the problem MIGHT have been that these TIFFs were stored on a network drive. When the files that were not retaining the georeferencing were pulled to the local machine, the georeferencing stuck. That said, we then had to have our end users pull those files local for the georeferencing to display correctly, so this was not the ultimate workaround, just a workaround. Some files did not have this problem even when stored on the network drive, so even this workaround was a bit random. Also, we did try to georeference plan sheets in Pro, and found that when we "saved" the georeferencing, the plan sheet would move off where we told it to be every time. We tried with multiple transformation types. We never did get it to stick. All in all this has been a significant Esri fail.
One other thing I noticed - and I have no idea whether it has anything to do with the problem - is that I started having this problem almost immediately (if not immediately) after I upgraded to 10.5.1. It was also not long after I started using Pro in a big way (although this problem is in Desktop). Any ideas?
I've had this same problem. What seems to be working for me is to hit "update display" first, then hit "update georeferencing"
Kyle,
Thanks so much for this solution. I have been using it for a few weeks and it works great. Thanks again!
"Update Display" then "Update Georeferencing" worked immediately after I read it, then I imported my next TIFF (with no pyramids) and tried again. Update Display looked good, then Update Georeferencing kicked it a hundred feet west.
I'm almost glad this failed since this particular project is for live review, and the non-pyramid drawings just ooze down the screen like molasses, so I really didn't want that to be the solution.
I fear without universal consistency we have no way of knowing what's actually working and what's just luck, but as another data point for troubleshooting, I'll add that I do have several large TIFFs crammed into this one data frame.
John on 10.5.1
