Geodatabase diagrammer, Visio 2007, ArcGIS 9.3
2148
7
06-30-2010 07:19 AM
SabrinaGonzalez_Toro
Hi every one,
I was trying to install GDB Diagrammer with ArcGIS 9.3.1 and Visio 2007.  I followed the instructions in the readme file but always get a runtime erron when generating the diagram.
I reviewed several old forums but no answer about this configuration worked.
Now I have found a solution.  If any one gets the Runtime error "invalid file name" or "file not found" while generating the diagram, copy the vsd and vss files in "C:\Archivos de programa\Microsoft Office\Office12\3082".
It solved the problem with VISIO 2007
DerekLaw
Esri Esteemed Contributor
FYI:
For other users who are interested in using MS Visio 2007 with CASE tools for geodatabase schema design, we have a KnowledgeBase Article on the topic:
FAQ: Can Microsoft Visio 2007 be used as a CASE tool for geodatabase schema design?
Hope this helps,
ShadyAbushaara
Hi every one,
I do it but problem still occared
this massage appeare   "run time error '-20302465466
JoeEncinas
I am also getting this same message. The suggestion of coping the .vss & .vsd files to the program management - office12 - 3082 .... did not solve it. Any more thoughts?
JennyGonzalez
Same issue but using ArcGIS 9.3.1 and Visio 2010.
JefferyGregg
Same problem here but with ArcGIS 10.0 and Visio 10
IanMacInnis
Geodatabase Diagrammer works for me with Visio 2010 and ArcGIS 9.3.1.  I entered the path for the folder containing the template and stencil files (.vst and .vss) to the File Locations dialog in Visio (File / Options / Advanced / File Locations ...), as indicated in the readme file.
I had to open the template and stencil files from within Visio and save them again, selecting the "Current Visio Format" option (i.e., Visio 2010 format).  Geodatabase Diagrammer seems to have difficulty when Visio opens the files in an older format.
When running Geodatabase Diagrammer, you need to add .vsd to the end of the output file name.
Ian
TyroneUdokpan
Hi All,
Where can I locate the install for ArcGIS 10? This is a great tool.
