Geocoding Question
1137
04-04-2014 12:40 PM
IgorBalotsky1
I would like to build a geocoder that supports an address that has this type of format:
500 block of Main Street
500 blk. Main Street
Above addresses should just be geocoded to 500 Main Street.
Any clues? It seems that none of the locator styles seems to support this but it's very important for my organization. Or maybe I am just overlooking something simple?
Igor
TimWitt
Igor,
maybe you can build a locator using a street file as your reference data, with the Dual Range Address Locator format. In the From Left field and To Left Field you can put in 500 and do the same for From Right and To Right fields.
This means if somebody types in 500 Main Street it will take them to said block.
This is the only way I see it work.
Hope this helps!
Tim
JoeBorgione
You might take a look at US One Range locator type.
http://resources.arcgis.com/en/help/main/10.2/index.html#/Commonly_used_address_locator_styles/00250...
