Geocoding: Address Locator Problem
2714
08-12-2011 07:01 AM
AzizulAlam1
Hello,
I was trying to create address locator in ArcCatalog 10. But it was failed. I am trying this with the tutorial file called Atlanta GDB. Here is the executing code.
Executing: CreateAddressLocator "US Address - Dual Ranges" "G:\GIS Data\GeoCoding\Atlanta.gdb\Streets' 'Primary table'" "'Feature ID' OBJECTID VISIBLE NONE;'*From Left' L_F_ADD VISIBLE NONE;'*To Left' L_T_ADD VISIBLE NONE;'*From Right' R_F_ADD VISIBLE NONE;'*To Right' R_T_ADD VISIBLE NONE;'Prefix Direction' PREFIX VISIBLE NONE;'Prefix Type' PRE_TYPE VISIBLE NONE;'*Street Name' NAME VISIBLE NONE;'Suffix Type' TYPE VISIBLE NONE;'Suffix Direction' SUFFIX VISIBLE NONE;'Left City or Place' CITYL VISIBLE NONE;'Right City or Place' CITYR VISIBLE NONE;'Left ZIP Code' ZIPL VISIBLE NONE;'Right ZIP Code' ZIPR VISIBLE NONE;'Left State' STATE_ABBR VISIBLE NONE;'Right State' STATE_ABBR VISIBLE NONE;'Left Additional Field' <None> VISIBLE NONE;'Right Additional Field' <None> VISIBLE NONE;'Altname JoinID' <None> VISIBLE NONE" G:\GIS Data\GeoCoding\Atlanta.gdb\Atlanta #
Please help me to solve this. An step by step help is preferred (I am new at ArcGIS 10)
Tags (3)
AzizulAlam1
Hello again,
Is there nobody to resolve this?
ShanaBritt
Azizul:
Have you tried saving the address locator to a file folder instead of the file geodatabase?
Was there an error code when the tool failed?
-Shana
