Geocode streets without knowing ZIP
7935
6
09-24-2010 06:54 AM
MarkBrickley
In previous versions of the software there was an address locator named US Streets that would let you geocode without knowing a zip code (provided you had the street, city and state).  Version 10 has reduced the number of locators...and I don't see a comparable locator that doesn't require zips.  As I recall, version 9 had a "US Streets" as well as one named "Streets with Zone" (if you had zip codes).
I have a large number of address for Providence, RI, but don't have zip codes; Providence is divided into several zip codes, so I can't just assign a single zip code to my data.  Is there a way to geocode my addresses?
Thanks for any help on this,
Mark
BruceHarold
Esri Frequent Contributor
Hi Mark
When you create a locator using a 10 style you may set the relevant zone field to <None> and not specify it at run time - in your case ZIP.  There is an issue with 10.0 which requires that at least one zone field must be non-null, but this is fixed at SP1.
Regards
havansurat
How do I geocode addresses in 10.1 without having zipcode field in address table. I created an address locator in 10.1 with Dual Ranges address locator and I point it to none for zone dropdown menu option but still couldn't able to geocode addresses. Please let me know.
Havan
JonathanQuinn
Esri Notable Contributor
It sounds like you're running into NIM081790.  Check the workaround and see if it works for you.
NishaKini
I created a zipcode column in my excel sheet and left it blank. Just chose this blank zipcode column and continue geocoding, you should be able to do it. Hope this helps.
-Nisha
JoeBorgione
The bug was submitted on Jun 15 2012: when was 10.1 released?  Shortly there after, wasn't it?
And the fix is still a work around?
Hmmmm.
That should just about do it....
ShanaBritt
The behavior you described does fit NIM081790, which has also been discussed in the thread titled Geocoding-10-vs-10.1. I recently posted a response to a question about whether this bug will be fixed or not. Please see my response at http://forums.arcgis.com/threads/61960-Geocoding-10-vs-10.1?p=284440&viewfull=1#post284440.
-Shana
