Generic Server Error Message
2147
08-06-2012 07:52 AM
BenjaminViss
Hi All-
Hopefully someone could shed some light on the error message I've been getting.
See the attached screen shot.
The file is a standard .csv on the companies' server and I imported it as a personal geodb tbl into a personal geodb (also on the server). I've been able to geocode other ones like it, but this one gives me half way through the error:
"Generic Server Error Message".
Any ideas would be helpful.
Benjamin
JoeBorgione
Nothing like an error message to sink your teeth into....
Check your table; somewhere in there I bet you have a null value or an empty value or something along those lines.
BenjaminViss
For sure.
Thanks for the feed back, I was thinking that was the cause, and sure enough.
Right after I posted the thread, I double-checked my tables and found the culprit.
Thanks for your effort.
