Generate a grid of latitude values
16163
19
04-30-2010 07:18 AM
ToddMcDonnell
I need to convert a 30m elevation grid to a grid that gives values for the cell latitude rather than elevation.
I tried converting the GRID to point, adding x,y data to the points, then converting back to GRID using the y-coordinate as the value, however, the large region I am working with is preventing the processes from completing successfully.
Any advice will certainly be appreciated.
Todd
SeanMcLaughlin
What is the area, or how large of an area is it?
LukePinner
Is the grid in a geographic coordinate system?
If so, just set your output extent and cell size (ArcToolbox environment settings or Spatial Analyst toolbar options) to match your DEM then use $$YMAP built in scalar variable in a SOMA/MOMA tool or Raster Calculator expression:
E.g.
C:\workspace\latgrid = $$YMAP
Luke
PS: For info...
Built-in GRID scalar variables:
$$NROWS: the number of rows in the analysis window
$$NCOLS: the number of columns in the analysis window
$$CELLSIZE: the current cell size specified in the analysis environment
$$WX0: minimum x-map coordinate of the current analysis window
$$WY0: minimum y-map coordinate of the current analysis window
$$WX1: maximum x-map coordinate of the current analysis window
$$WY1: maximum y-map coordinate of the current analysis window
$$XMAP: x-map coordinate for the center of the processing cell
$$YMAP: y-map coordinate for the center of the processing cell
Built-in GRID constants.
PI: 3.142
E: 2.718 (e)
DEG: 57.296 (Degree to radian conversion)
GAMMA: 0.577
PHI: 1.618
Built-in grids.
$$ROWMAP
$$COLMAP
DanielLusher
Luke (or anyone else who can help),
I've read your post on this thread, and your thread on the old forums (http://forums.esri.com/Thread.asp?c=93&f=1740&t=182407&mc=6#msgid538607), but I'm struggling to get the $$xmap scalar variable to work with the SOMA tool.  It works in the Raster Calculator, but since I am trying to create a model, I need to use the SOMA tool.  At the moment, I am trying
$$xmap = (D:\...\Base Data\dem3_4m)
in the "Map Algebra expression" box, and have tried variations including switching the order of variables, spaces and no spaces, no equal sign, etc.  I still get an error saying that "$$xmap = is not a valid function or operator."  I also cannot find where it would be in the "Usage" listing.
I am currently running ArcView 9.3.1 SP 2 with the Spatial Analyst extension, on Windows 7.
Thank you for any ideas you might have!
DanielLusher
Figured it out - needed to set the extent, snap raster, and cell size in the "Model Properties" to make it run.  Put "$$xmap" in the "Map Algebra expression" text box and it ran fine.
JenifaLatha
Dear Sir
I need to create a lattitude grid from the DEM. I have gone through the threads and followed the steps. When I type the statement $$YMAP in SOMA window after setting the extent, working directory and cell size by the spatial analyst > options, i get an error message that "Syntax error at locations 0 of expressions $$YMAP". I even changed the expression as E:\Ph.D\Data_dump\DEM = $$YMAP. How to access these built in functions? Kindly help me sir.
With Thanks
EmmanuelJjunju
I have tried this is arcGIS10 raster calculator  and it doesn't work!! Any new detailed instructions on how to generate the grid of latitudes?
See screen capture attached please.
toddsams
I have not tried the raster calculator method.
However, I have had luck using the function "genvecgrid" in the Geospatial Modeling Environment (GME). After generating the vector point grid I added x-y coordinates to the attribute table. Then, created a raster from these points using the y-coordinate field as values. I think I chose a bilinear interpolation technique when doing this.
GJtB
I have the same Problem as ejjunju ($$XMAP or $$xmap doesn't work in ArcGIS 10)
I want to create rasters with x-Values and do not have a clue how to Do it with the raster calculatur. I could create point-features, use "Add XY" and then convert it to rasters, but as I have to automatize it it seems to be too complicated.
I also have problems finding documentation/ tutorials on Map Algebra syntax. Does anyone know some sources for this
Greetings
Gerald
MannyGimond
Unfortunately, ESRI removed those grid functions from 10.0. However, there is a Python alternative, see this link .
