GDAL library for custom raster format in ArcGIS 10.2?
6620
02-04-2014 01:58 AM
MarcN
For ArcGIS 10 and 10.1 there is a sample to support custom raster formats with GDAL driver.
http://resources.arcgis.com/de/gallery/file//image-management/details/?entryID=457D0F2B-1422-2418-7F...
Does this version for 10.1 also work for 10.2? Currently I can not find an update for 10.2.
RinkeHeida
Hi Marc,
We support some custom raster formats throug GDAL:
ARIS ASCII Grid Reader for ArcGIS
ARIS APS Reader (OPS output) for ArcGIS
Both drivers needed an upgrade from GDAL 1.6 to 1.8 while moving from ArcGIS 10.0 to ArcGIS 10.1
At the time we had to move to ArcGIS 10.2 there was no info to be found about ArcGIS 10.2 and GDAL, but apparently it just worked as ArcGIS 10.2.x is still using GDAL 1.8.
So both our tools work as one version with ArcGIS 10.1/10.2/10.2.1/10.2.2
RinkeHeida
Now I want to upgrade to ArcGIS 10.3 but now our drivers do not work, and there is no information on any changes.
The custom raster format page is moved now to:
http://www.arcgis.com/home/item.html?id=cb7065146659428e9eadc9cd88268b9f
But it still ends with info on ArcGIS 10.1
AdhimoolamD
Hi Rinke,
Did you find any solution regarding this gdal1.8 issue in ArcGIS Desktop 10.3.x? kindly let me know
RinkeHeida
Hi Adhimoolam,
If you download (through Open button) on http://www.arcgis.com/home/item.html?id=cb7065146659428e9eadc9cd88268b9f  it will now contain an updated version of gdal1.8.
Note: it is still called gdal1.8 but changes have been made between the version for ArcGIS 10.1/10.2 and the one for ArcGIS 10.3/10.3.1.
