Field of type esriFieldTypeOID is not editable within a new RecordSet
1737
08-09-2011 07:40 AM
MCMADMIN
Building a new RecordSet with a field of esriFieldType.esriFieldTypeOID and Editable = true is not editable at all! This fieldtype implies obviously, that the field can't be edited. If you use esriFieldType.esriFieldTypeInteger instead, it works fine.
Example:
// define new recordset with cols id and txt
IRecordSet rs = new RecordSet();
IRecordSetInit rsDefinition = rs as IRecordSetInit;
IFields rsFields = new Fields();
IFieldsEdit rsFieldsEdit = rsFields as IFieldsEdit;
rsFieldsEdit.FieldCount_2 = 2;
IField rsField = new ESRI.ArcGIS.Geodatabase.Field();
IFieldEdit rsFieldEdit = rsField as IFieldEdit;
rsFieldEdit.Name_2 = "id";
//rsFieldEdit.Type_2 = esriFieldType.esriFieldTypeOID; <<< is not editable!!!
rsFieldEdit.Type_2 = esriFieldType.esriFieldTypeInteger; //<<< use Integer instead
rsFieldEdit.Editable_2 = true; // doesn't make esriFieldTypeOID editable!!!
rsFieldsEdit.set_Field(i, rsField);
rsFieldEdit.Name_2 = "txt";
rsFieldEdit.Type_2 = esriFieldType.esriFieldTypeString;
rsFieldEdit.Length_2 = 80;
rsDefinition.CreateTable(rsFields);
ICursor rsCursor = rsDefinition.Insert();
IRowBuffer rowBuffer = rsDefinition.CreateRowBuffer();
rowBuffer.set_Value(0, 1); // throws execption if esriFieldTypeOID is used!!!
rowBuffer.set_Value(1, "blabla");
Bug or feature? Even if the created Recordset never will be stored in a DB, you can't use e.g. field definitions from an existing table, but have to replace esriFieldTypeOID with esriFieldTypeInteger.
(AGS 10 SDK)
MelitaKennedy
Esri Notable Contributor
OIDs are maintained by ArcGIS to ensure an unique identifier per feature. So a field marked as esriFieldTypeOID won't be editable.
Fundamentals of ObjectID Fields
Melita
