Please be aware that renaming the ESRI folders is a factory reset of ArcGIS, and therefore all third party tools, custom scripts, and/ or custom toolbars currently installed will need to be re-installed as a result. Also, you will need to re-connect all existing folder connections if data was saved in the ESRI folders.
Windows 7:
***Renaming the ESRI Folder in the C: drive***
1. Open Control Panel > Appearance and Personalization > Folder Options > View Tab
2. Select the radio button to Show hidden files, folders, and drives
3. Right-click on the Windows Start Icon > Windows Explorer
4. Navigate to C:/Users/YourUsername/AppData/Roaming/ESRI
**If the AppData folder is not visible, you may need to perform the following steps to display the general toolbar: Organize menu > Layout > Menu Bar. Then to display the AppData folder, choose the Tools menu > View Tab > Show Hidden files, folders, or drives > Apply > OK
5. Right click on the ESRI folder and select rename. Rename the folder to oldESRI
***Renaming the ESRI Folder in the Registry Editor***
1. Navigate to the Start Menu
2. Navigate to Run�?�
3. Type in "regedit" (to get the registry editor)
4. Click OK
5. Expand on the "hkey current user" folder in the folder tree
6. Expand on the "software" folder
7. Right click on the "ESRI" folder and rename the folder "ESRIold" Tab
Below you will find instructions on restting the normal templates for ArcCatalog, ArcMap, and ArcToolbox.
For ArcCatalog:
1. Close ArcCatalog & ArcMap
2. Navigate to root C:\Documents and Settings\USERNAME\Application Data*\ESRI\ArcCatalog *(if hidden go to tools folder options view)
3. Open the Templates folder
4. There will be a "Normal.gxt" file. Please right click on that file, and rename it to something besides Normal. Then re-start ArcCatalog.
For ArcMap:
2. Navigate to root C:\Documents and Settings\USERNAME\Application Data*\ESRI\ArcMap *(if hidden go to Tools folder options view)
4. There will be a "Normal.mxt" file. Please right click on that file, and rename it to something besides Normal. Then re-start ArcMap.
For ArcToolbox
2. Navigate to root C:\Documents and Settings\USERNAME\Application Data*\ESRI\ArcToolbox *(if hidden go to Tools folder options view)
3. There will be an "ArcToolbox.dat" file. Please right click on that file, and rename it to something besides ArcToolbox. Then re-start ArcMap Tab
Dana Kern
ESRI Support Service - Redlands, CA
