Field Calculator: A field name was not found...
3469
01-23-2013 09:07 AM
RobertMartin2
Hi all,
I'm using the Field Calculator with some basic Python syntax to recalculate a field. The new data is coming from a joined Excel worksheet. My expression is:
!'Commercial-Active$'.OLD![:-3]
When I run this I get the error: "A field name was not found or there were unbalanced quotation marks." I know the field name is correct because I'm selecting it as-is from the Fields box. Does anyone know what this is all about?
Thanks!
RobertMartin2
Well I think I figured it out... when I tried re-adding the Excel sheet, the Add Data dialog displayed it as Commercial-Active$' (that is, with a trailing quote mark). Removing the hyphen also got rid of the quote mark, and then everything played nicely.
Another mysterious ArcGIS workflow...
RobertMartin2
