Ferramenta Join
728
09-23-2013 04:56 AM
MichelyTavares
I'm working with geodatabase in ArcGIS Desktop and try to run a join my table (INSC_MUNICIPAL) with a table that I have access through sql connection (REGISTRATION). But I can not run, the following error appears:
The number of matching records for the join:
- No matches found by joining [INSC_MUNICIPAL_1] from <LOTES_01> with [REGISTRATION] from <preceita.DPVIEW.%vwIMOVEL>
I checked the type and field size are matched.
Also looked manually and there is the same inscription on each table. I tested exporting the table for a sql dbf table and managed to run normally join.
[ATTACH=CONFIG]27668[/ATTACH]
This error only occurs when I'm using a table with remote connection.
Can anyone help me?
