Feature class locked/involved in phantom Geometric network
3959
08-28-2013 11:47 AM
JoshWhite
Honored Contributor
I tried creating a geometric network on a feature dataset and there was an error and if I remember correctly, ArcMap decided to crash. Now one of my feature classes is forever locked. I try to delete it and it says it can't be deleted. I try to create a new geometric network and it says it is unavailable because it participates in another network. There is no other Geometric Network in the feature dataset. For now I copied the feature class so I could add it to the Network but now I have the extra feature class that is useless. I tried to edit it by deleting the feature in it and I get an error that says the feature could not be deleted and most recently my mxd just crashes when I try to edit it.  I'm actually trying to decide if I even need a Geometric Network.  I'm creating a feature that shows the routes of our Sanitation trucks as they pick up trash.  I had originally wanted to show the flow arrows but I'm not sure if it worth having the headaches of a Geometric Network to achieve this.  I use Geometric Networks for my utilities and it is beneficial there.  Any ideas?
Josh White, AICP
Principal Planner
City of Arkansas City
ChrisDupont
Not a timely response, considering this post is three years old, but as I recently had this issue (geometric network creation was halted midway through, could not create a new geometric network with those objects), I thought I would comment for anyone else that has the same problem.
It looks like that as part of the geometric network creation process, the application will first create a topology object. If the creation process crashes or is halted halfway through, that topology object will remain -but since it is not an expected object, most would just see that the geometric network was not created and not notice that there is now a topology object. That object will need to be deleted before you can start the creation process again, since a feature class can either participate in a topology object or a geometric network, but not both. (And to the deletion issue, you can't delete objects that participate in either until you delete the top level topology or geometric object).
JoshWhite
Honored Contributor
I honestly can't remember what I ended up doing.  Most likely I called technical support to resolve it. I do know that I don't have the issue currently.
Josh White, AICP
Principal Planner
