Feature class in a Topology & Geometric Network?
794
05-25-2012 11:06 AM
JoshuaDamron
Greetings,
  I'm building geometric networks for utility data and could use someone�??s two cents on the basics of geodatabase management.  I've fixed errors using topology and am ready to create the network.  Geometric networks are a bit new to me.
  From my experience feature classes within a feature data set can either be in a topology or geometric network, not both.  This means that to check my data for errors I build topology, fix the errors, then either delete my topology and create a geometric network or export the feature classes to a new feature dataset and create a geometric network in the new data set.  If this is correct then I can no longer use topology in the future to check edits and fix errors.  Additionally, because a water zone polygon would not be included in the water pipe network, I lose the ability to define say my water zone topology as always containing a water main line/water structure point because the line/point features are in another dataset.  I feel like I'm missing something basic... are the connectivity rules in a geometric network such that they replace the need for topology validation checks?
Is it expected that when a validation/error check is needed that the feature classes will be copied/exported/imported back and forth between data sets?  or is there an aspect of geometric networks that resolves this issue?
Lots of questions I know... Thanks in advance.
