I'm using ArcGIS version 10.2.2
If I use CopyFeatures, FeatureClassToFeatureClass, Append management tools, updated features show up correctly sorted on ObjectID. In my GP scenario I'm not the owner of dataset/feature class. I'm working with another user having privilege to insert update delete records.
In my GP script, I delete old features from a FC using arcpy.DeleteFeatures_management.
and Inserted new features in this by using arcpy.da.insertcursor,
record inserted in the correct order, I can see from auto generated object ids.
But on opening attribute table in ArcMAP or preview in ArcCatelog the table don't show records sorted on Object ID. I tried to rebuild indexes, set spatial index on FC using owner user. It did not help
What's the difference. How I can see data by sorted order of objectId?
Thanks and Regards
Lalit Arora
