Export a single attribute from a fGDBR database?
1668
06-23-2013 09:52 AM
KimFalinski
Hello all,
I have a complicated fGDBR database with an attribute table with about 20 attributes associated with 1200 or so different types of soil. For the model I'm running (on external software), I need a simple GRID file based on a single attribute.  How do I export a raster image of just a single attribute (such as depth) into its own layer?  When I use Copy Raster, it doesn't give me the choice of field.  Do I need to just eliminate all the attributes except the one I'm interested in?
I am using 10.0, and have tried all of the Raster options in Data Management, to no avail.
Is there a way to do this?  Perhaps I don't understand the Raster Attribute table well enough?
Thanks in advance,
Kim
Luke_Pinner
MVP Regular Contributor
Glad I could help. Can you click the green check mark next to the answer to indicate that it answered your question.
Luke_Pinner
Use the Lookup (Spatial Analyst) tool.
KimFalinski
Thank you!  That was easy.
Luke_Pinner
