export a postgis database with greek characters - HELP
1726
06-13-2011 12:06 AM
apolele
Hi
I encounter a problem. Specificallly, i try to export a postgis database to a geodatabase using the extension data interoperability. Unfortunately, i didn't achieve it, because tha data of postgis has greek characters!
What's going on with encoding??
So could anyone help me??
Thanks in advnace!
BruceHarold
Esri Frequent Contributor
Hello Alelentz
Unfortunately the underlying engine for Data Interoperability 10 is not unicode aware; this is fixed in the next release.  You may want to try PostGIS dumper utility pgsql2shp and see if it correctly creates a codepage file (.cpg extension) and if so you can then import the shapefile into any geodatabase including unicode data.
Regards
apolele
Hi Bruce
Today, i was searching a lot in the internet, and i realized that the pgsql2shp is one of the solutions for my problem. Also, i can do the same thing with the GDAL\OGR library.
Anyway, my issue is solved and i want to thank you, for your reply.
But i want to ask and something else.. when you say that "...this is fixed in the next release..." which version of arcgis do you mean?? ArcGIS 10.1/2 or ArcGIS 11??
Regards!
BruceHarold
Hello again
The 10.1 release of Data Interoperability will be unicode aware.
Regards
KowchKoh
Another tool can solve your problem. The ST-Links PgMap. It works with ArcGIS 10 and it is unicode aware. And the data load by PgMap is compatible with QGIS, Manifold.
stevepeedell
Hello again
Regards
Of course this does beg the question why it has taken until 10.1 to support Unicode........?
Steve
