Hello ESRI and fellow GIS Users
I was hoping someone could help with the dataset_id, raster_type, sources and filter properties given the error message below?
I have 100 tifs stored on D:\test2015\gisdata which I would like to add to a raster mosiac dataset.
Kind Regards
Nicholas
<AddRasters>
<AddRaster>
<dataset_id>Dataset_ID</dataset_id>
<raster_type>Raster Dataset</raster_type>
<Sources>
<data_path>D:\test2015\gisdata</data_path>
</Sources>
<filter>tif</filter>
<update_cellsize_ranges>UPDATE_CELL_SIZES</update_cellsize_ranges>
<update_boundary>UPDATE_BOUNDARY</update_boundary>
<update_overviews>NO_OVERVIEWS</update_overviews>
<maximum_pyramid_levels>#</maximum_pyramid_levels>
<maximum_cell_size>0</maximum_cell_size>
<minimum_dimension>1500</minimum_dimension>
<spatial_reference>#</spatial_reference>
<sub_folder>SUBFOLDERS</sub_folder>
<duplicate_items_action>ALLOW_DUPLICATES</duplicate_items_action>
<build_pyramids>NO_PYRAMIDS</build_pyramids>
<calculate_statistics>NO_STATISTICS</calculate_statistics>
<build_thumbnails>NO_THUMBNAILS</build_thumbnails>
<operation_description>#</operation_description>
<force_spatial_reference>NO_FORCE_SPATIAL_REFERENCE</force_spatial_reference>
</AddRaster>
<M<message> Calling (arcpy.AddRastersToMosaicDataset_management) <Error><type>critical</type><text>ERROR 000622: Failed to execute (Add Rasters To Mosaic Dataset). Parameters are not valid. ERROR 000628: Cannot set input into parameter raster_type. </text></Error></Message>
Hi, did you got the answer for this?
