Error: ???synchronize replica failed???,
14849
21
01-02-2014 09:40 PM
by Anonymous User
Not applicable
Original User: [email protected]
Error: �??synchronize replica failed�?�,
I wanted synchronize the data from enterprise geodatabase to file geodatabase with replica name that has previously created but I got the message below:
[ATTACH=CONFIG]30200[/ATTACH], [ATTACH=CONFIG]30201[/ATTACH], [ATTACH=CONFIG]30202[/ATTACH]
What might be the issue here?
Thank you
Best
Jamal
JamalNUMAN
Legendary Contributor
to update:
I downgraded a workstation to version 10.1 and the replica synchronized successfully.  After this successful synchronization, I tried again from the 10.2 client, and it worked (but no changes to transfer).  I then added a record to the parent geodatabase so there would be changes to transfer, and synchronization from 10.2 was successful.
There are two replicas related to this data--one is a file geodatabase, the other is an SDE geodatabase, both one-way.  The same issue presents in both.
Thanks for the input Marianne
Best
Jamal
Jamal Numan
by Anonymous User
Not applicable
Original User: MLF
You are welcome.  I have just logged this with Esri Support, and if it proves to be a bug, will update the thread with a NIM.
