Error registering feature class with non binary shape field type
745
07-19-2012 03:22 AM
PedroAbreu
Hi all,
Back in the good old 10.0 I was creating a spatial view between one Table and two Feature Classes defined as follow:
sdetable
-o create_view
-T "spatialView_ROUTES_EVENT"
-t "PODS.DBO.GEOM_LINEAR_EVENT,PODS.DBO.EVENT_RANGE,PODS.DBO.GEOM_ROUTES"
-c "PODS.DBO.GEOM_LINEAR_EVENT.SHAPE,PODS.DBO.GEOM_LINEAR_EVENT.OID,PODS.DBO.EVENT_RANGE.FEATURE_ID,PODS.DBO.GEOM_ROUTES.STATUS,PODS.DBO.EVENT_RANGE.EVENT_GUID"
-w "PODS.DBO.GEOM_LINEAR_EVENT.EVENT_GUID=PODS.DBO.EVENT_RANGE.EVENT_GUID AND PODS.DBO.GEOM_LINEAR_EVENT.GEOM_ROUTES_OID=PODS.DBO.GEOM_ROUTES.OID"
-i sde:sqlserver:[instance]
-s [server]
-D PODS
-u [user]
-p [pass]
Now that I am migrating the project to 10.1 the view is registered but it just doesn't work. ArcMap dosn't recognize it as a spatial view.
After some research i come across with this bit of information:
http://resources.arcgis.com/en/help/main/10.1/index.html#/Creating_a_database_view_in_ArcGIS_for_Des...
"You cannot create a spatial view if the spatial column is a binary geometry data type"
I went back and checked the way I was registering the Feature Class and I realize that yes, I was registering the Shape field as a binary type:
sdelayer -o add -l dbo.GEOM_ROUTES,SHAPE -t SDEBINARY -e nl+M -C OID,SDE -g GRID,5700 -x 0,0,200 -z 0,200 -G 30731 -P HIGH -L off -i sde:sqlserver:[instance] -s [server] -D PODS -u [user] -p [pass]
So, I thought, let's change the Shape field type to something else that SQL Server 2012 can recognize:
1st attempt:
sdelayer -o add -l dbo.GEOM_ROUTES,SHAPE -t GEOMETRY -e nl+M -C OID,SDE -g GRID,5700 -x 0,0,200 -z 0,200 -G 30731 -P HIGH -L off -i sde:sqlserver:[instance] -s [server] -D PODS -u [user] -p [pass]
Error: Invalid layer storage type (-196)
2nd attempt:
sdelayer -o add -l dbo.GEOM_ROUTES,SHAPE -t GEOGRAPHY -e nl+M -C OID,SDE -g GRID,5700 -x 0,0,200 -z 0,200 -G 30731 -P HIGH -L off -i sde:sqlserver:[instance] -s [server] -D PODS -u [user] -p [pass]
Can anybody help me out with this one...?
Pedro
VinceAngelo
Esri Esteemed Contributor
The best way to define a native SQL geometry column is with SQL (CREATE TABLE ...), which you
would then register with ArcSDE via 'sdelayer -o register').
If you do use 'sdelayer -o add' for native geometry, you can't specify SDEBINARY-specific options
like grid size.  I'm also not sure if GEOMETRY supports measures, but I know you can't use a geodetic
GEOGRAPHY type with UTM data.  You should use a DBTUNE keyword that corresponds to the native
type.
- V
PedroAbreu
Hi all,
First of all: Thanks for the reply, Vince 😉
Second, here's how I solve the issue:
Create Table 1:
CREATE TABLE [MyFeatClass] (
[OID] int NOT NULL,
[SHAPE] geometry NULL,
[MyTable_Guid] uniqueidentifier NOT NULL
Create Table 2:
CREATE TABLE [MyTable] (
[Guid] uniqueidentifier NOT NULL,
[Name] nvarchar(50) NOT NULL,
GO
Create View:
CREATE VIEW [MyView]
AS
SELECT
MyFeatClass.OID,
MyFeatClass.SHAPE,
MyTable.Name,
FROM MyFeatClass INNER JOIN
MyTable ON MyFeatClass.MyTable_Guid = MyTable.Guid
Register Table 1 as FeatureClass:
sdetable -o register -t MyFeatClass -c OID -C SDE -u [user] -p [pass] -D [database] -i sde:sqlserver:[instance]
sdelayer -o add -l MyFeatClass,SHAPE -t GEOMETRY -e nl+M -C OID,SDE -g GRID,5700 -x 0,0,200 -z 0,200 -G 30731 -P HIGH -L off -i sde:sqlserver:[instance] -s [server] -D [database] -u [user] -p [pass]
Register View:
sdetable -o create_view -T "MyView" -t "MyFeatClass,MyTable" -c "MyFeatClass.SHAPE,MyFeatClass.OID,MyTable.Name" -w "MyFeatClass.MyTable_Guid=MyTable.Guid" -i sde:sqlserver:[instance] -s [server] -D [database] -u [user] -p [pass]
sdelayer -o add -l MyView,SHAPE -t GEOMETRY -e np3 -C OID,SDE -g GRID,5700 -x 0,0,200 -z 0,200 -G 30731 -P HIGH -L off -i sde:sqlserver:[instance] -s [server] -D [database] -u [user] -p [pass]
VinceAngelo
You've got something wrong if you can both create the view with SQL and "register"
it with 'sdetable -o create_view'.  Views are registered exactly the same as native
tables, with 'sdelayer -o register'. The create_view option of 'sdetable' should only
be used with SDEBINARY/SDELOB storage.
- V
PedroAbreu
To be honest, I don't know what dark magic runs behind the scene... But it was the only way that I found for ArcCatalog to recognize the Views.
About the SDEBINARY on the initial post, I showed a link to a esri page that claims that views won't work with Binary storage type.... And they weren't working with SDE 10.1 (they were working with SDE 10.0)
VinceAngelo
If you need dark magic to make ArcSDE work, you're probably using DBO and/or
schemas named other than the same as the login user.
I doubt support for SDEBINARY has been removed, but haven't had the time
to post-install 10.1 on my laptop to demonstrate it.
- V
