Error loading GML file
3206
7
09-13-2011 10:10 PM
HaydenFoley
Hi There,
I have the Data Interoperability extension installed and can perform a successful 'Quick Export' to GML and then import back again the exported file into ArcMap.
However, I have an externally sourced GML file that simply will not load and returns the error "Error when writing schema: A unique destination feature type name can not be generated for.."
Please provide advice on how I can load  up the below. Does it need to be reformated to a later version of GML. If so what would the new format look like applied to the example below?
Any help greatly appreciated
<?xml version='1.0' encoding='UTF-8'?>
<schema
xmlns='http://www.w3.org/2000/10/XMLSchema'
xmlns:gml='http://www.opengis.net/gml'
xmlns:xlink='http://www.w3.org/1999/xlink'
xmlns:xsi='http://www.w3.org/2000/10/XMLSchema-instance'
xsi:schemaLocation='http://www.opengis.net/gml/feature.xsd'>
<gml:Polygon srsName='http://www.opengis.net/gml/srs/epsg.xml#28355'>
<gml:outerBoundaryIs>
<gml:LinearRing>
<gml:coord><gml:X>505461.452639567</gml:X><gml:Y>5404659.39500733</gml:Y></gml:coord>
<gml:coord><gml:X>505478.218825224</gml:X><gml:Y>5404650.16791261</gml:Y></gml:coord>
<gml:coord><gml:X>505418.476206284</gml:X><gml:Y>5404545.29881424</gml:Y></gml:coord>
<gml:coord><gml:X>505385.948338288</gml:X><gml:Y>5404567.63763573</gml:Y></gml:coord>
<gml:coord><gml:X>505437.142484404</gml:X><gml:Y>5404623.22069171</gml:Y></gml:coord>
</gml:LinearRing>
</gml:outerBoundaryIs>
</gml:Polygon>
</schema>
MitaHajirakar
Hi Hayden,
For some reason the DI is unable to generate unique layers with your GML file.  I'd need to take a look at the GML file to understand why.  Are you able to pass it on so I can take a look?
Kind regards,
Mita Hajirakar
Safe Software, Inc.
AliceShepherd
I am having the same problem loading an externally sourced gml file using the quick import tool.  Also get the error message "Error when writing schema: A unique destination feature type name can not be generated for ". Did you find a solution to this problem?
Alice
MitaHajirakar
Hi Alice,
Again I'd need to take a look at your GML file.  Are you able to send it to me?  What version of ArcGIS are you using?
Kind regards,
Mita Hajirakar
Safe Software, Inc.
BradHuff
Same problem, has a fix been found? Thanks
MitaHajirakar
Hi there,
I'd need to take a look at your data and try to reproduce the problem so I can investigate further - are you able to send it to me?
Mita Hajirakar
Safe Software, Inc.
HarmenKampinga
it's good to see that individual issues are resolved, but what is the true solution to this problem I'm facing too?
BruceHarold
Esri Frequent Contributor
Hi All
When looking at these GML issues we find that many files are not valid GML.  There can be many reasons, for example:
http://fmepedia.safe.com/articles/Error_Unexpected_Behavior/GML-geometries-not-read
You can test any GML/XML with the XMLValidator. You can test GML using the schemas that come with Data Interop in: C:\Program Files (x86)\Esri\Data Interoperability (x86)\xml\schemas\schemas.zip\gml
If you want to test the validity of your files please open a support incident and we'll take a look.
Regards
