Copied Rasters From ArcSde 10 To 10.1 Problems
1577
01-25-2013 11:28 AM
by Anonymous User
Not applicable
Original User: alattin
Recently, we've upgraded a server to 10.1. However, when we copied our imagery from ArcSDE 10 to ArcSDE 10.1 the raster images display only as tables. Any help is appreciated.
Thank you.
AsrujitSengupta
Aaron,
You seem to be hitting the following bug:
http://support.esri.com/en/bugs/nimbus/TklNMDg0NzAx
Alternate Solution
Use ArcCatalog 10.x to transfer the rasters.
If the raster is copied/imported using SDE commands, use Desktop 10 to register with the geodatabase.
Regards,
