Error displaying flow arrow in network. ArcSDE 10.1
2937
8
09-24-2012 08:09 AM
RobertBorchert
Honored Contributor
We migrated a customer to ArcSDE 10.1 and recreated the Geometric Network.
When finished we went into a session and when we try to display the flow arrows we get this message.  The Vector GIS... is one of our feature classes in the network
Underlying DBMS error [Microsoft SQL Server Native Client 10.0: Cannot call methods on int.] [Vector.GIS.PriUGElectricLineSegment]
Thanks for any assistance you give.
JamesM1
With the "Cannot call methods on int" error, your customer could be running into a known NIM with 10.1.
NIM082866 - An error of "layer fail to draw" appears in 10.1 when selecting both "set flow direction" and "display arrows" in a geometric network.
http://support.esri.com/en/bugs/nimbus/TklNMDgyODY2
ChrisBoudreaux
The NIM082866 is not on the list of 10.1 sp1 fixes. (source:http://downloads.esri.com/support/downloads/other_/189810.1_SP1_Announcement.pdf)
For the utility world running geometric networks, this is unacceptable.  How do we request a reevaluation for inclusion into 10.1 sp1 or a patch to fix this?
BenFerguson
I've seen this issue as well with 10.1.
CraigGillgrass
We're aware of this issue and plan to address it in 10.1 SP2.  If you haven't already, contact Technical Support and have your account associated with the bug so that you can properly track it.
MichaelSmith1
We are seeing this same error message, but running SDE 9.3.1 and using 10.1 SP1 client.  The error does not appear in 10.0 client or 9.3.1 client.  So that begs the question, is this an SDE issue or a desktop issue?
CraigGillgrass
This is a Desktop/Client issue.
CésarPires
I have the same error only when data is stored as sdebinary.
CraigGillgrass
This issue causing this error; NIM082866, is being addressed in 10.2.
