ArcGIS 10.1
851
03-08-2013 08:27 AM
DanielOHanlon
I am trying to do some Geocoding. Last week i was able to upload a table, and the geocoding worked fine. Today i am trying and it will not work at all.
If i used an older PC which has 10.0 on it, the geocoding works fine.
I recently put on a patch for my 10.01 system. Is there an issue with the geocoding or is there a bug?
Also, i am unable to add address locators to my system.   Any Help?
SarahOsborne
Esri Alum
This is a good time to remind everyone that you are violating the terms of use if you do any batch geocoding (storing results) without a subscription.  http://blogs.esri.com/esri/arcgis/2013/02/21/terms-of-use-for-batch-geocoding/
Once you have a subscription, here is the information for connecting to the service for batch geocoding.
If you still have problems connecting, please contact technical support.
