error calculating a field using field calculator
7720
6
10-13-2011 12:33 PM
ChristiNelson1
Hi there,
I have an attribute table and have added a new field (AQU_PIPE_NAME).  To populate its selected fields, I would like to set it equal to the selected values in another field of the same table (EXTENSION).  I have made only the selected fields visible.  I ten right click on AQU_PIPE_NAME and click on Field Calculator.  I set the following operation:  AQU_PIPE_NAME = [EXTENSION] and receive the following error message:
"There was a failure during processing, check the Geoprocessing Results window...
Calculate Field [133038_10132011]
ERROR 000732 Input table does not exist or is not supported
Its a simple file .gdb attribute table.  Not sure why it wouldn't be supported.   No subtypes exist on this table and I made sure.
Helllp!
Christi
SamCoggins1
This maybe a dumb response. Does the new field support the data type you're trying to add to it? For example, you're not trying to add data from a text field to a short integer field are you?
JoshThompson1
I have found that ArcMap 10.0 is very sensitive as to how you name a layer in your Table of Contents.
So far I have found two instances of where I get an error when using the field calculator:
1.  If your layer name in the Table of Contents has extra spaces at the end.  (Fix: remove any extra spaces)
2.  If your layer name in the Table of Contents has has a slash "/".  (Fix: remove "/")
If you suspect that you might be running into this issue, try renaming the layer.
I don't know if Service Pack 3 will address this issue as I have not yet installed it.
Josh
JacksonTrappett
Thanks - this fixed it for me as well!
DanThompson
thanks this was driving me crazy. i knew my field types matched and couldnt figure out why i was getting the error
SaraJK
Thank you! This solved my problem! I also had a slash in one of my coded value domains and got the same error. I removed it and it was working again.
GeorgiaJackson
Is really a good question
