I have a single File Geodatabase that contains data in two projections. The database itself has 14 feature classes of which seven are in one projection and seven are in another projection.
Question 1:
Should I keep all the feature classes in the "root" folder of the Geodatabase, or should I have two separate feature datasets for each projection?
Question 2:
Should my File Geodatabase, Feature Dataset, and Feature Classes use proper case or lower case?
