error 001003
1490
12-13-2012 05:47 AM
alklaklzkalzk
Hi!
thank you for your help.
I'm having trouble using the intersect tool (analysis).
I've selected two shapefiles with the same coordinate system (WGS_1984)
however, when I want to apply the intersect tool, a wild "warning message" appears: datum conflict between input and output.
I can't find any solution to go through that warning, And my intersection can not be created.
Actually, I'd like to create a matrix relating environmental data to different geolocalized points.
thank you again for your help.
Adri
