An invalid character was found in text content.
2224
12-12-2012 06:28 AM
MeganZoch
I'm trying to bring feature data within a geodatabase into an .mxd document (ArcView 10.0). When I attempt to add it I get the "Open Failed" message: Error opening feature class. An invalid character was found in text content.
I've noticed this has happened to a couple of feature files within a geodatabase that were used in .mxd's prior to compression. Now the data is compressed in the geodatabase. I tried to uncompress to see if they'd work but still do not. Any suggestions?
Thanks!
JakeSkinner
Esri Esteemed Contributor
Hi Megan,
You may be encountering a bug that is now resolved in ArcGIS 10.1:
NIM060270  Compressing and Uncompressing a file geodatabase with the  Preview Tab open in ArcCatalog corrupts the last feature class previewed
As a workaround, try exporting the feature class to a shapefile and see if you are able to preview the shapefile.
MeganZoch
Thank you for your help.
I haven't upgraded to 10.1 yet though I assume it'll happen in the near future. Also I tried to "Export to Shapefile (single)" (by right-clicking on the file) and I got the following message:
ERROR 999999: Error executing function.
No support for this geometry type.
Failed to execute (FeatureClassToFeatureClass).
Any suggestions to fixing this without the 10.1 upgrade? Thank you.
JakeSkinner
Try creating a new feature class in another File Geodatabase and then use the Simple Data Loader to load data from the corrupt feature class to this one.
MeganZoch
I attempted what you suggested and recieved the Data Source Error "Failed in opening data source."
