create mosaic dataset with nitf wv-2
917
12-13-2012 10:09 AM
alkirschbaum
I'm having a problem creating a mosaic dataset using nitf (WV-2) imagery. I created a file geodatabase, created a mosaic dataset, added the first raster using nitf as the raster type. Then, following the help file, I brought in the same raster choosing WV-2 as the sensor type. The resulting mosaic dataset shows up white (nodata values) inside ArcMap (see attached image-nodata). If I click inside the footprint, the values for inside the footprint are all 'nodata.' If I just add the image through the 'add data' dialog, it shows up fine (see attached image-adddata).
Any ideas?
-al
