ERROR 000006: Could not open the address table.
2342
07-12-2011 12:08 PM
RyanShedd
I created an address locator based on a shapefile of roads for a county. I created my table in excel (.xlsx). Checked and rechecked column headers and address formats. when I try to geocode the addresses it tells me "000006 : Could not open the address table." help?
JoeBorgione
What version of ArcGis are you using. I don't think 9.3.1 and earlier will open xlsx files. If Im wrong about that, make super sure you have no spaces or special characters on you field names. Null values somewhere might toss you a curve as well.
That should just about do it....
JohnatanRojas
Try using 97-2003 Excel format. I had the same problem
BradNiemand
ArcGIS does not support xlsx format.  You can save it as a xls if it isn't too big or convert it to a csv and it will work.
