Defining Projection
2558
07-08-2011 08:48 AM
morganhunt
Hi, I am a newbie so please bear with me. I have downloaded some grids from the USGS and while I can open and view them in ArcView (9.2) there is no projection file. However, there was provided projection information on the website where I downloaded the grid. My issue is that when I go to define the projection for the grid, I can't locate the projection that they specified. I have copied below exaclty what I was given as to the projection of the grid:
For the merged aeromagnetic anomaly grid and map.
Projection = Spherical transverse mercator
Central meridian = 100° W.
Base latitude = 0° N.
Scale factor = 0.926
Spherical earth radius = 6,371,204 m
Horizontal datum = DNAG
MelitaKennedy
Esri Notable Contributor
If the files are still in Esri GRID format, make a text file called prj.adf and place this text in it:
projection transverse
units meters
parameters 6371204 6371204
0.926
-100 00 00
00 00 00
0.0
0.0
We don't have a separate spherical transverse mercator. Instead, you set the gcs/datum to use a sphere and that triggers the correct map projection equations.
If the raster's been converted to another format, try creating a text file called DNAG.prj and put this in it (as a single line)
PROJCS["DNAG",GEOGCS["GCS_STM1987",DATUM["D_STM1987",SPHEROID["STM1987",6371204.0,0.0]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Transverse_Mercator"],PARAMETER["False_Easting",0.0],PARAMETER["False_Northing",0.0],PARAMETER["Central_Meridian",-100.0],PARAMETER["Scale_Factor",0.926],PARAMETER["Latitude_Of_Origin",0.0],UNIT["Meter",1.0]]
Put DNAG.prj into the ArcGIS install location's Coordinate Systems, Projected Coordinate Systems folder. Now you can browse to it and set it as a raster's coordinate system in Define Projection Tool or the data's property page in ArcCatalog.
Melita
morganhunt
Thank you, Thank you, Thank you!
