DXF->shape error!! help please !!
1059
10-12-2011 04:57 AM
zerelliseifeddine
HI!!
i have a problem with ConvertFeatureClass(..) , i have Error "Open featureclass failed"
i Need a help please about this methode! why i have this error ?
private void Conversion2(string fileName, string currentView, string alias)
            string nom_repertoire = System.IO.Path.GetDirectoryName(fileName);
            string nom_fichier = System.IO.Path.GetFileName(fileName);
            String targetWorkspacePath = Environment.CurrentDirectory;
            int Count;
            IWorkspaceFactory pCadWKSFact = new CadWorkspaceFactory();
            IWorkspaceFactory targetWorkspaceFactory = new ShapefileWorkspaceFactoryClass();
            IFeatureWorkspace pWorkspace =    (IFeatureWorkspace)pCadWKSFact.OpenFromFile(nom_repertoire, 0);
            IWorkspace targetWorkspace = (IWorkspace)targetWorkspaceFactory.OpenFromFile(targetWorkspacePath, 0);
            IWorkspace sourceWorkspace = (IWorkspace)pCadWKSFact.OpenFromFile(nom_repertoire, 0);
            //IFeatureDataConverter_ConvertFeatureClass_Example(sourceWorkspace, targetWorkspace, "DXFfeatureclass", "shapefeatureclass");
            IFeatureWorkspace targetFeatureWorkspace = (IFeatureWorkspace)targetWorkspaceFactory.OpenFromFile(targetWorkspacePath, 0);
            IFeatureDataset pFeatureDataset = pWorkspace.OpenFeatureDataset(nom_fichier);
           // IFeatureDataset targetFeatureWorkspaceDataset = (IFeatureDataset)targetFeatureWorkspace;
            IDataset targetWorkspaceDataset = (IDataset)targetWorkspace;
            IDataset sourceWorkspaceDataset = (IDataset)sourceWorkspace;
            IName sourceWorkspaceDatasetName = sourceWorkspaceDataset.FullName;
            IName targetWorkspaceDatasetName = targetWorkspaceDataset.FullName;
            IWorkspaceName sourceWorkspaceName = (IWorkspaceName)sourceWorkspaceDatasetName;
            IWorkspaceName targetWorkspaceName = (IWorkspaceName)targetWorkspaceDatasetName;
            IFeatureClassContainer pFeatureClassContainer = (IFeatureClassContainer)pFeatureDataset;
            // Create a name object for the shapefile and cast it to the IDatasetName interface.
            IFeatureClassName sourceFeatureClassName = new FeatureClassNameClass();
            IDatasetName sourceDatasetName = (IDatasetName)sourceFeatureClassName;
            sourceDatasetName.Name = "streets";
            sourceDatasetName.WorkspaceName = sourceWorkspaceName;
            // Create a name object for the DXF  feature class and cast it to the IDatasetName interface.
            IFeatureClassName targetFeatureClassName = new FeatureClassNameClass();
            IDatasetName targetDatasetName = (IDatasetName)targetFeatureClassName;
            targetDatasetName.Name = "AtlantaStreets";
            targetDatasetName.WorkspaceName = targetWorkspaceName;
            IFeatureClass pFeatureClass;
            // Conversion(fileName, currentView, alias);
            for (Count = 0; Count < pFeatureClassContainer.ClassCount - 1; Count++)
                pFeatureClass = pFeatureClassContainer.get_Class(Count);
                // Create the objects and references necessary for field validation.
                IFieldChecker fieldChecker = new FieldCheckerClass();
                IFields sourceFields = pFeatureClass.Fields;
                IFields targetFields = null;
                IEnumFieldError enumFieldError = null;
                // Set the required properties for the IFieldChecker interface.
                fieldChecker.InputWorkspace = (IWorkspace) pWorkspace ;
                fieldChecker.ValidateWorkspace = (IWorkspace) targetFeatureWorkspace;
                // Validate the fields and check for errors.
                fieldChecker.Validate(sourceFields, out enumFieldError, out targetFields);
                if (enumFieldError != null)
                    // Handle the errors in a way appropriate to your application.
                    Console.WriteLine("Errors were encountered during field validation.");
                // Loop through the output fields to find the geomerty field
                IField geometryField;
                for (int i = 0; i < targetFields.FieldCount; i++)
                    if (targetFields.get_Field(i).Type == esriFieldType.esriFieldTypeGeometry)
                        geometryField = targetFields.get_Field(i);
                        // Get the geometry field's geometry defenition
                        IGeometryDef geometryDef = geometryField.GeometryDef;
                        //Give the geometry definition a spatial index grid count and grid size
                        IGeometryDefEdit targetFCGeoDefEdit = (IGeometryDefEdit)geometryDef;
                        targetFCGeoDefEdit.GridCount_2 = 1;
                        targetFCGeoDefEdit.set_GridSize(0, 0); //Allow ArcGIS to determine a valid grid size for the data loaded
                        targetFCGeoDefEdit.SpatialReference_2 = geometryField.GeometryDef.SpatialReference;
                        // we want to convert all of the features
                        IQueryFilter queryFilter = new QueryFilterClass();
                        queryFilter.WhereClause = "";
                        // Load the feature class
                        IFeatureDataConverter fctofc = new FeatureDataConverterClass();
                        IEnumInvalidObject enumErrors = fctofc.ConvertFeatureClass(sourceFeatureClassName, queryFilter, null, targetFeatureClassName, geometryDef, targetFields, "", 1000, 0);
                        break;
VinceAngelo
Esri Esteemed Contributor
You're more likely to get help if you post in the appropriate forum, which is probably
over in ArcObjects - All Development Languages. When you post there, be sure to
specify which version and service pack of ArcGIS you are using. It will also make
your post more readable if you use the CODE tags and try to preserve indentation.
- V
zerelliseifeddine
ok thanks i will do it 🙂
