domain
4674
14
09-07-2016 03:11 AM
jayasudha
I have created a feature class in WGS84 with default settings.
There is default domain created as below. What does it mean ?
xmin, xmax (-400, 9006799.25474099)
ymin, ymax (-400, 9006799.25474099)
NeilAyres
MVP Alum
That's the domain and tolerance page, not the extent.
That domain is the min & max limits to the GCS vales allowed in the feature class.
DanPatterson_Retired
looks like a weird extent which doesn't make sense given the coordinate system.  Can you provide some context... is the geodatabase in the same wgs84 coordinate reference?
JayantaPoddar
MVP Alum
Is it GCS_WGS_1984? Looks like you have defined a Projected Coordinate System with datum WGS_1984.
It would be helpful if you could share the screenshot of the spatial reference of the feature Class/layer.
Think Location
jayasudha
jayasudha
What is the dataframe? the geodatabase?
by Anonymous User
Not applicable
You can change XY extents from feature class properties,
Are you able to do that or still have an issue..
JoeBorgione
Does this feature class have any features in it yet?  When I create an empty feature class using WGS 84 I get:
NeilAyres
MVP Alum
jayasudha
I think GCS domain is -180, -90, 180, 90, please advice
