display row and column of a raster
5932
09-19-2012 06:31 AM
EstherAmler
Dear all,
maybe someone can help me with this issue:
I have a raster file and can locate single pixels with the "identify" button. The location is given in decimal dgrees. Do you know a possibility to display row and column of the pixel (in relation to UL as row 1, column1)?
I use 9.3 currently and can't find an easy solution.
Any idea anybody?
Thanks in advance, Esther
SteveLynch
Search for "02-03-2011 06:58 AM" in http://forums.arcgis.com/threads/364...values?p=74323
I.e use FlowAccumulation
Steve
SteveLynch
EstherAmler
" just set your output extent and cell size (ArcToolbox environment settings or Spatial Analyst toolbar options) to match your DEM then use $$YMAP built in scalar variable in a SOMA/MOMA tool or Raster Calculator expression:
E.g. C:\workspace\latgrid = $$YMAP"
hmm, sorry, I don't understand that. Note I don't use ArcInfo or so...
yesterday i found this solution:
"1. Create two fields in the attribute table, using type Long Integer.
2. Right-click on each field and select the Field Calculator.
3. Enter the following equation:
Field1:
Int(Abs((X - ) / Z) + 1)
Field2:
Int(Abs((Y - ) / Z) + 1)
Where X and Y are the starting X/Y location of the raster, and are the X/Y location of the point, and Z is the pixel size.
For Example:
Int(Abs ((-80 - ) / .00083333333) + 1)
Int(Abs ((35 - ) / .00083333333) + 1)
Where -80 and 35 are the starting X/Y location of the raster, and are the X/Y location of the point, and .00083333333 is the pixel size. "
Find it quite complicated but would do that. unfortunately I get an error in the field calculator. Maybe you know what and stand for?
Best, Esther
SteveLynch
Steve
EstherAmler
thank you!
another thing, simple formula for single points is:
lon -> col:  (col - 0.5)*pixel size + Upper left Y
lat -> row:  Upper left X - (row + 0.5)*pixel size
