Disconnect User Permissions?
5959
09-16-2014 08:58 AM
TimHayes
I have an ArcGIS for Server 10.2.2 Enterprise Geodatabase in SQL Server 2008 R2. It was set up with Database Permissions in SQL Server, not Windows/OS. I am the Database Administrator.
I need to disconnect a user from our Enterprise Geodatabase and when I try to do so it says I do not have the permissions.
In ArcCatalog, I went to my Enterprise Geodatabase - Administration - Administer Geodatabase - Connections. I chose the user to disconnect but then a message pops up saying I do not have the permissions to do so.
What additional permissions do I need to set in SQL Server Management Studio to be able to disconnect a user from our Enterprise Geodatabase?
Tags (1)
AsrujitSengupta
Removing connections from a geodatabase in SQL Server:
ArcGIS Help (10.2, 10.2.1, and 10.2.2)
The geodatabase administrator in SQL Server:
You will have to grant that user the processadmin fixed server role to grant it sufficient permissions to disconnect other connections.
AsrujitSengupta
TimHayes
Thanks, your help was very useful. Problem solved.
AsrujitSengupta
Great!! Mark the thread as Answered or the reply helpful, if possible.
