disabling export tool for particular users,
2011
04-14-2013 01:21 PM
JamalNUMAN
Legendary Contributor
I�??m wondering if there is a way to disable the export tool for particular users such that those users will never be able to copy/export/store the date (features class)
[ATTACH=CONFIG]23484[/ATTACH], [ATTACH=CONFIG]23485[/ATTACH], [ATTACH=CONFIG]23486[/ATTACH]
Is that possible?
Is this done in SQL or ArcGIS?
Thank you
Best
Jamal
Jamal Numan
by Anonymous User
Not applicable
Original User: vangelo
No, it's not possible.  Any user with SELECT access to a table can find a way
to export that data.
- V
MarcoBoeringa
Jamal,
Any users not allowed to export data, should probably not be using ArcGIS for Desktop at all... there is just to many access points to data and tools for data conversion.
Instead, they probably should be using some custom web-application to access non-editable ESRI Image or OGC WMS services serving out just images and not true features. By the way: you can access these webservices too through the ArcMap interface. This might be a part solution: make the Feature Classes only directly accessible to the geodatabase administrator, and than create ESRI Map / Image or WMS webservices using ArcGIS for Server to allow access to other users from within ArcMap.
If the users do need editing capabilities, than a custom web editing application using ESRI Feature Services or OGC WFS-T (transactional WFS) might be in order, but that would still allow access to feature geometry data somehow, but at least not directly from an interface like ArcGIS for Desktop with its many options...
by Anonymous User
Not applicable
Original User: [email protected]
Jamal,
Many thanks Vince and Marco for the very useful answer,
I thought that there might be a simple approach to grant users permissions for editing only without being able  to export/copy the data
Best
Jamal
