DGN TIN to ESRI TIN/Raster
7538
05-27-2011 03:07 PM
MarkWilson3
I am trying to convert some TINs that are in Microstation DGN files to ESRI raster format.
I wrote a script that converted the 3d polylines in the DGN file to an ESRI TIN then to a raster.  This worked great for about half of the files.
As for the other half, I can't even get the geometry to display in the ArcCatalog Preview window.  I can open the DGN files with the free Microstation Viewer app.  I can also use Data Interoperability Quick Import to pull the tin into a FGDB as polygons with Z values.  The problem with this is that when I try to use those polygons to build a TIN, it not only takes forever, only a very small slice on the right side of the tile is converted.
This really can't be that hard can it?  Any ideas on a better way to do the conversion would be appreciated.
Mark
PS - I have also tried Spatial ETL without much success.
SaraGilbert
Mark,
I'm attempting the same thing.  Please let me know if you had any success.
Thanks, Sara
MarkWilson3
I will post the script that i used.  I think that it ended up working but can't remember for sure since it was almost a year ago.
# Converts multiple DGN TIN files to ESRI elevation raster
# Mark Wilson
# May 2011
# Imports
import os
import time
import sys
import arcpy
# Check out any necessary licenses
arcpy.CheckOutExtension("3D")
# Set environments
arcpy.env.overwriteOutput = True
# Variables
DGN_folder = r"D:\"
output_folder = r"D:\"
sr = "PROJCS['HENNEPIN COUNTY',GEOGCS['GCS_User_Defined',DATUM['D_User_Defined',SPHEROID['User_Defined_Spheroid',6378418.941,298.2572242549207]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]],PROJECTION['Lambert_Conformal_Conic'],PARAMETER['False_Easting',500000.0],PARAMETER['False_Northing',100000.0],PARAMETER['Central_Meridian',-93.38333333333334],PARAMETER['Standard_Parallel_1',44.88333333333333],PARAMETER['Standard_Parallel_2',45.13333333333333],PARAMETER['Latitude_Of_Origin',44.79111111111111],UNIT['Foot_US',0.304800609601219]]"
dont_list = []  #['1tin_v8.dgn', '2tin_v8.dgn', '10tin_v8.dgn', '11tin_v8.dgn', '12tin_v8.dgn', '13tin_v8.dgn', '14tin_v8.dgn', '15tin_v8.dgn', '16tin_v8.dgn', '17tin_v8.dgn', '18tin_v8.dgn', '19tin_v8.dgn', '20tin_v8.dgn', '21tin_v8.dgn', '22tin_v8.dgn', '23tin_v8.dgn', '24tin_v8.dgn', '25tin_v8.dgn', '26tin_v8.dgn', '27tin_v8.dgn', '28tin_v8.dgn', '29tin_v8.dgn', '30tin_v8.dgn', '31tin_v8.dgn', '32tin_v8.dgn', '33tin_v8.dgn', '34tin_v8.dgn', '35tin_v8.dgn', '36tin_v8.dgn', '37tin_v8.dgn', '38tin_v8.dgn', '3tin_v8.dgn', '40tin_v8.dgn', '41tin_v8.dgn', '46tin_v8.dgn', '4tin_v8.dgn']
logfile = output_folder + "\\DGNTIN_to_raster_log.txt"
bail = False
# Functions
def scan_dir(folder, filetype = "dgn", subdir = False):
    '''scans a directory for files of a specific extension and returns them in a list'''
    file_names = []
    ext_len = len(filetype)
    items = os.listdir(folder)
    for item in items:
        if item[- (ext_len + 1):] == "." + filetype:
            file_names.append(item)
    for item in file_names:
        print item
        f.write(item)
        f.write("\n")
    return file_names
def DGN_to_GDB(DGN_name, DGN_workspace, out_workspace):
    '''Takes a TIN in Microstation DGN format and creates a GDB
    by using the Data Interoperability Quick Import
    This also assumes that you can correctly identify the correct parameters for the
    Quick Import tool (possibly by creating a Model Builder model and exporting to
    Python)'''
    f.write("\n\n   PROCESSING  ")
    f.write(str(DGN_name))
    DGN_path = DGN_workspace + "\\" + DGN_name
    print "\n   PROCESSING    ", DGN_path
    parameter = []
    parameter.append('''DGNV8,''')
    parameter.append(DGN_path)
    parameter.append(''',"RUNTIME_MACROS,""METAFILE,dgnv8,_XPNDCELL,YES,_PRESERVE_INSERTS,NO,EXPAND_UNNAMED_CELLS,NO,PRESERVE_UNNAMEDCELL_INSERTS,NO,SPLIT_MULTITEXT,YES,_TEXTTAGS,NO,EXPLODE_DIMENSION_ELEM,YES,_DROP_COMPLEX,NO,READ_XREF_FILES,NO,USE_XREF_PARENT_MODEL,NO,READ_XREF_UPTO_FIRST_LVL,NO,_IGDS_MSLINKS,NO,_IGDS_FRAMME,NO,_IN_UNITS,IGDS_MASTER_UNITS,OVERRIDE_GLOBAL_ORIGIN,NO,_UOR_GLOBAL_ORIGIN_X,,_UOR_GLOBAL_ORIGIN_Y,,APPLY_WORLD_FILE,YES,_MERGE_SCHEMAS,YES"",META_MACROS,""SourceMETAFILE,dgnv8,Source_XPNDCELL,YES,Source_PRESERVE_INSERTS,NO,SourceEXPAND_UNNAMED_CELLS,NO,SourcePRESERVE_UNNAMEDCELL_INSERTS,NO,SourceSPLIT_MULTITEXT,YES,Source_TEXTTAGS,NO,SourceEXPLODE_DIMENSION_ELEM,YES,Source_DROP_COMPLEX,NO,SourceREAD_XREF_FILES,NO,SourceUSE_XREF_PARENT_MODEL,NO,SourceREAD_XREF_UPTO_FIRST_LVL,NO,Source_IGDS_MSLINKS,NO,Source_IGDS_FRAMME,NO,Source_IN_UNITS,IGDS_MASTER_UNITS,SourceOVERRIDE_GLOBAL_ORIGIN,NO,Source_UOR_GLOBAL_ORIGIN_X,,Source_UOR_GLOBAL_ORIGIN_Y,,SourceAPPLY_WORLD_FILE,YES"",METAFILE,dgnv8,COORDSYS,""""""ESRIWKT|HENNEPIN COUNTY|PROJCS[""""HENNEPIN COUNTY"""",GEOGCS[""""GCS_User_Defined"""",DATUM[""""D_User_Defined"""",SPHEROID[""""User_Defined_Spheroid"""",6378418.941,298.2572242549207]],PRIMEM[""""Greenwich"""",0.0],UNIT[""""Degree"""",0.0174532925199433]],PROJECTION[""""Lambert_Conformal_Conic""""],PARAMETER[""""False_Easting"""",500000.0],PARAMETER[""""False_Northing"""",100000.0],PARAMETER[""""Central_Meridian"""",-93.38333333333334],PARAMETER[""""Standard_Parallel_1"""",44.88333333333333],PARAMETER[""""Standard_Parallel_2"""",45.13333333333333],PARAMETER[""""Latitude_Of_Origin"""",44.79111111111111],UNIT[""""Foot_US"""",0.304800609601219]]"""""",IDLIST,,__FME_DATASET_IS_SOURCE__,true"''')
    parameters = '''"'''.join(parameter)
    f.write("\n")
    f.write(str(parameters))
    new_GDB_name = DGN_name[3:5] + ".gdb"
    new_GDB_path = out_workspace + "\\" + new_GDB_name
    print "new GDB path = ", new_GDB_path
    f.write("\n")
    f.write(str(new_GDB_path))
##    if not arcpy.Exists(new_GDB_path):
    try:
        arcpy.QuickImport_interop(parameters, new_GDB_path)
        print arcpy.GetMessages()
        f.write("\n")
        f.write(str(arcpy.GetMessages()))
        f.write("\n")
    except:
        f.write("\n")
        f.write("\n")
        if bail: sys.exit()
    return new_GDB_name
def GDB_to_TIN(GDB_name, GDB_workspace, out_workspace):
    '''Takes a GDB and uses all of the polygon feature classes with Z values
    to create a new ESRI TIN'''
    GDB_path = GDB_workspace + "\\" + GDB_name
    print "\n\n    GDB path = ", GDB_path
    arcpy.env.workspace = GDB_path
    FCs = arcpy.ListFeatureClasses()
    print "FCs = ", FCs
    FC_params = []
    for FC in FCs:
        FC_path = GDB_path + "\\" + FC
        print "FC path = ", FC_path
        desc = arcpy.Describe(FC_path)
##        if desc.HasZ:
        FC_params.append("'" + FC_path + "' Shape.Z hardline <None>")
    print "\n  FC params = ", FC_params
    params = ";".join(FC_params)
    print params
    f.write("\n")
    f.write(params)
    f.write("\n")
    new_TIN_name = "TIN_" + GDB_name[:2]
    new_TIN_path = out_workspace + "\\" + new_TIN_name
    try:
        arcpy.CreateTin_3d(new_TIN_path, "", params, "CONSTRAINED_DELAUNAY")
        f.write("\n")
        f.write("\n")
        try:
            time.sleep(30)
            arcpy.Delete_management(GDB_path, "")
            f.write("\n")
            f.write("\n")
        except:
            f.write("\n")
            f.write("\n")
            if bail: sys.exit()
    except:
        f.write("\n")
        f.write("\n")
        if bail: sys.exit()
    return new_TIN_name
def TIN_to_raster(TIN_name, TIN_workspace, out_workspace):
    '''Converts an ESRI TIN to raster'''
    TIN_path = TIN_workspace + "\\" + TIN_name
    raster_name = TIN_name[4:6]
    raster_path = out_workspace + "\\" + raster_name
    try:
        print TIN_path
        print raster_path
        arcpy.TinRaster_3d(TIN_path, raster_path, "FLOAT", "LINEAR", "CELLSIZE 5", "1")
        f.write("\n")
        f.write(arcpy.GetMessages())
        f.write("\n")
        try:
            arcpy.Delete_management(TIN_path, "")
        except:
            if bail: sys.exit()
    except:
        f.write("\n")
        f.write("\n")
        if bail: sys.exit()
def main():
    DGN_list = scan_dir(DGN_folder, "dgn")
    for TIN in DGN_list:
        if TIN not in dont_list:
            new_GDB = DGN_to_GDB(TIN, DGN_folder, output_folder)
            new_TIN = GDB_to_TIN(new_GDB, output_folder, output_folder)
            TIN_to_raster(new_TIN, output_folder, output_folder)
# Body
start_time = time.clock()
f = open(logfile, 'w')
main()
f.close()
print
print "*" * 80
stop_time = time.clock()
elapsed_time = stop_time - start_time
print "Start Time: ", start_time
print "Stop Time: ", stop_time
print "Elapsed time = " + str(round(elapsed_time / 60, 1)) + " minutes"
print "*" * 80
good luck!
DeniseFisher
Good boy!
AndrewDonakowski
Just wondering if it's possible to adjust this script for my own use. Sort of a python newb here, so any guidence you have would be most appreciated. I am trying to convert a TIN from a Microstation .dgn file to an esri TIN that I could use in ArcScene. I have entered in the correct file path for my .dgn and the output location where I want the TIN, but after running the script, I only have a blank .txt log file.
Do I need to adjust any of the other variables? Also, I am running this from IDLE. Do I need to run it as a tool in ArcMap to specify any of the parameters?
Any insight you might have on converting a .dgn to a TIN is much appreciated.
Thanks!
Andy
BriannaNoblin
is there any way to do this process without using Python script. I have ArcMap 10 with 3D and Spatial Analyst tools. I have imported a 3D dgn file into my map and need to create a TIN raster. Im new to all this so sorry if this isn't an appropriate place to ask this question, and thanks in advance for any help.
