.dem Data Layer has visible tilings
2394
08-09-2013 06:00 AM
salomonsantos
Dear Community,
ich was searching for my problem but was not able to find a solution.
I got a .dem package of Alaska and add them as a layer in ArcMap.
What I see is this:
[ATTACH=CONFIG]26611[/ATTACH]
Is there a way to fix this and get a clean image?
Thanks alot!
santos
edit: I found out how to do it (mosaic to new raster) - but stuck on a new problem. 🙂
The result of the new raster is much brighter and the white is "burned out".
the peaks of mountains become flat... I added an example. Anybody can help with that?
[ATTACH=CONFIG]26615[/ATTACH]
The bottom one is the new rastered - but the white blows out.
salomonsantos
Can not edit my post, sry for adding new one.
Just a close image on how the differents look. Left the new raster with artifacts, right the original.
[ATTACH=CONFIG]26626[/ATTACH]
by Anonymous User
Not applicable
Original User: jimcousins
When you mosaic your rasters to a new file. you change the lowest low value and the highest high value, so the stretched display of data needs to cover a larger range. You could set the range explicitly by setting the stretch type to Minimum-Maximum, and setting the statistics to "from custom settings".
Regards,
Jim
salomonsantos
Thx Jim,
worked for the wrong values on the peaks.
But it does not change the resolution of the new raster.
Could there be something wrong with the cell size?
Because it looks like a bad resolution, but could be some raster patterns, too. 🙂
by Anonymous User
Not applicable
The default is to use the coarsest cellsize for the output, so perhaps you have a file at a different resolution that is causing some downsampling. You can set the output cellsize in the environment tab.
