HOW CAN I ADD AN SQL SERVER INSTANCE DIFFERENT FROM AN SQL EXPRESS INSTANCE
1767
08-13-2013 11:02 AM
OLANIYANOLAKUNLE
I have serious difficulties trying to connect to an SQL Server instance, different from an express instance, anytime I try to connect to the instance I get this error message
"Connections to this edition of the database server are not supported"
Any suggestions.
VinceAngelo
Esri Esteemed Contributor
You can't use the Express client ("Database Server") to connect to a non-Express
database.  You can only connect to a non-Express instance by installing an enterprise
ArcSDE geodatabase and connecting through the enterprise ArcSDE interface
("Database Connections").
- V
VinceAngelo
- V
OLANIYANOLAKUNLE
Thanks for answering my question, I just found out that I need an authorization code to connect to a non-Express
database, does ESRI have any installation setup for the enterprise ArcSDE geodatabase? Thank you.
VinceAngelo
Yes, there are detailed installation instructions in the documentation.
- V
