Deleting and populating a table using attribute rules / triggered on insert to another table
921
06-12-2023 06:17 AM
KIVANC
Hi
I have a survey record table where users input each conducted survey for a given area. This table has survey_area, (area code) date_start (date of survey), and frequency (surveying freq. in days) attributes. I would like to create a separate "survey planning" table to show upcoming surveys based on the latest survey and the frequency of each area. When a survey is done, planning table should show upcoming surveys for the next 2 years. Whenever the same area is surveyed next, the table should update all the dates based on the latest survey date. That's because a survey could be late or early and planning table should always show an up to date plan.
My logic is to create an attribute rule triggered after each insert to first check the planning table, delete all entries with the same survey_area attribute and create new ones from the latest entry based on the new survey date.
With a basic understanding of arcade, I can get the data, filter etc but I don't know how to delete and populate the planning table. Could you please help?
MarceloMarques
you can look into an arcpy python script or arcgis pro add-ins for further customization.
ArcGIS Developers
| Marcelo Marques | Esri Principal Product Engineer | Cloud & Database Administrator | OCP - Oracle Database Certified Professional | "About: In 1992, I embarked on my journey with Esri Technology, and since 1997, I have been working with ArcSDE Geodatabases, right from its initial release. Over the past 33 years, my passion for Spatial Databases and GIS data has become a central part of my career.." | “ The mountains are calling and I must go.” – John Muir |
