Deleted
2692
07-25-2012 02:44 AM
JoshTownsend
Deleted
KathrinSchulte-Braucks
Zonal Statistics as Table could be what you are looking for. The tool calculates several statistical measures (MEAN; MAX; MAX; MIN; STD;....) for all the pixels in each zone (aka polygon of a shapefile):
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//009z000000w8000000.htm
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#/How_Zonal_Statistics_works/009z000000w...
Use your Building ID as zone field.
You can then join the output table to your original footprint shapefile and copy the mean height values into the footprints shapefile's attribute table.
Hope that helps.
Kathrin
