Delete is grayed out for only one set of data within a GDB.
11140
22
09-15-2014 01:41 PM
Kevin_Sieger
New Contributor III
Using 10.1, ArcCatalog, personal geodatabase with two feature datasets.
In one of the feature datasets I am able to delete the dataset or any of the feature classes within that dataset but when I try to delete the other feature dataset or a feature class in it the Delete is grayed out. Is my GDB corrupted or a bug, or??? There isn't a lock on the database either when I'm trying to do this.
This is all occurring in the BISDM3.mdb I downloaded from Esri.
AsrujitSengupta
Regular Contributor III
Kevin_Sieger
New Contributor III
I uploaded it but it created another post.
BISDM3.mdb
AsrujitSengupta
Kevin A Sieger Ok, I was able to reproduce the behaviour.
This is occurring because the FloorLines feature class is a part of the Transportation_ND Network Dataset. Once I removed that feature class from participating in the network dataset, the delete option is available again.
JacobKohute
New Contributor II
Do you have a link where I can download that database. I'm a little suspicious of it myself. Especially since it's an mdb, those things are notorious for staying locked when they're really not.
Kevin_Sieger
New Contributor III
I don't.
What I've done in the past is Zip it up and change the extension to .notzip so it clears the firewall. Will that work?
JacobKohute
New Contributor II
That will work or change it to a .txt and I can change it back. Email: jkohute@decaturutilities.com
Kevin_Sieger
New Contributor III
BISDM3.mdb
JacobKohute
New Contributor II
I'm embarrassed that took this long to figure out. It has a network dataset so if you don't have the Network Analyst extension installed and turned on in ArcCatalog you won't be able to modify the network or features that take part in it.
AsrujitSengupta
This case isn't about the extension. Even with the extension turned on, the delete for that feature class will be greyed out, till that feature class is a part of the Network Dataset.
JacobKohute
New Contributor II
True, sorry I didn't pick up on that. You'll still have to have the extension enabled to be able to modify the network.
