Delete failed: ???lock request conflicts with an established lock???
8642
5
05-21-2014 09:22 PM
JamalNUMAN
Legendary Contributor
A layer owner is not able to delete it in an enterprise geodatabase as shown in the screenshots below:
[ATTACH=CONFIG]33989[/ATTACH], [ATTACH=CONFIG]33990[/ATTACH], [ATTACH=CONFIG]33991[/ATTACH]
The enterprise geodatabase accessed by the owner of the layer shows ???insufficient permissions??? as the ???disconnect user??? is selected
[ATTACH=CONFIG]33992[/ATTACH], [ATTACH=CONFIG]33993[/ATTACH]
What might be the issue here? How the owner can???t delete what he\she owns?
Thank you
Best
Jamal
Jamal Numan
by Anonymous User
Not applicable
Original User: cherylc
Hi Jamal
Connect as the admin user and disconnect the 'old' connection.
Regards
Cheryl
by Anonymous User
Not applicable
Hi Jamal
Regards
Cheryl
EmadAl-Mousa
it seems you have orphan connection. either close your ArcCatalog and try again, or check the connection lock using "sde" user geodatabase administrator GUI.
Regards,
by Anonymous User
Not applicable
Original User: Jamal432@gmail.com
Hi Jamal
Regards
Cheryl
Many thanks Cheryl and Emad for the help. Finally it is deleted
[ATTACH=CONFIG]34064[/ATTACH], [ATTACH=CONFIG]34065[/ATTACH], [ATTACH=CONFIG]34066[/ATTACH], [ATTACH=CONFIG]34067[/ATTACH]
In general,
�?� how the SA can delete a layer considering that he\she is not the owner?
�?� How to disallow users to add feature classes to the database?
Best
Jamal
Best
Jamal
EmadAl-Mousa
SA user in sql server is a powerfull user so the user can drop any database object.
to disallow users to create feature classes, the user connecting the geodatabase should not have the "create table" privilege.
Regards,
by Anonymous User
Not applicable
Regards,
Many thanks Emad,
Unchecking the �??create table�?� disallow a user to create feature class.
[ATTACH=CONFIG]34121[/ATTACH]
What is missing on permissions is that the admin can�??t disallow a user to be able to export a particular feature class.
[ATTACH=CONFIG]34122[/ATTACH]
