delete duplicate line features?
11846
12
08-15-2017 12:04 AM
AYGÜNALBAYRAK
I want to clean my data which is occured from line features. I try to get one line feature among other intersecting line features.
DanPatterson_Retired
ways to Identify duplicates and delete duplicates exist as tools in Arctoolbox for attributes and if the shape field is being compared, the geometries.  There is some tolerance, but 'generally close' isn't really supported
  Find Identical and Delete Identical but you need an Advanced license
AYGÜNALBAYRAK
thanks for your help but I have too many partial data. Is there any other method which facilitate my processes?
by partial, do you mean that pieces of a polyline overlap but not the whole pair?
Haven't had the need to use the Finding Duplicate Geometry in the Data Reviewer if you have it
AYGÜNALBAYRAK
I have ArcGIS 10.4. I attach the gdb. I try to delete layers which overlap each other and delete others until getting one feature. The features are partial.
JoshuaBixby
MVP Esteemed Contributor
I haven't had a chance to look at the data, but can you clarify "delete layers which overlap each other?"  If you have two layers that overlap each other, do you want both to be deleted or just one?  If just one, which one?  How do you determine which is the correct overlapping layer to delete and which to leave?
AYGÜNALBAYRAK
I have a data which created in irregular way so there is so many data which overlapped or intersected with each other. It is important that which data I deleted.
AbdullahAnter
Honored Contributor
If the duplicates lines are in one layer, use Dissolve—Help | ArcGIS Desktop  tool. then explode ( advanced editing toolbar ) them again or use Multipart To Singlepart—Help | ArcGIS Desktop
AYGÜNALBAYRAK
Thanks for your help. I am trying to use your method now.
AYGÜNALBAYRAK
I tried the solution and it works  The only thing that I should do is allocating different layers from each other and applying this method for each of them severally.
