Data Logger/Aquisition - Polygons
6628
13
08-16-2014 05:17 AM
JonathanMerrills
Hello,
I need to purchase some hardware that will allow me to log points whilst I walk around the edge of a landform in order to create a polygon in ArcMap.
I'm not sure what the cost and availability of such things are but beyond price, obviously accuracy and portability are prime concerns, as is ease of compatibility with ArcMap. I am UK based.
Forgive me if this is a common question but I'm short on time and a real novice in this field. Any help or information that you can give would be very much appreciated.
kind regards
stefanstamenov
You use ArcPad as a software, right?
JonathanMerrills
Hi, no I don't currently. I haven't used any data collection software or hardware.
is Arcpad essential? I just need to collect the polygons and get them into Esri.
stefanstamenov
I think it is more practical to collect points, not tracks and afterwards draw polygons in ArcGis, or whatever software you use. If use ArcGis, usually you use ArcPad also, both are ESRI products and compatible. In all cases you will need receiver and software on the field.
stefanstamenov
And you are looking for a GPS receiver for a field work.
JonathanMerrills
If a GPS receiver will allow me to record my position as I walk around (thus measuring) a feature in a format that is compatible with ESRI then that sounds perfect, yeah.
stefanstamenov
Yes, a GPS receiver can record your points in shape format if it has ArcPad on it. Otherwise you will have to convert for example the GPX file into shape. If you use Garmin hand held receiver for example.
stefanstamenov
The choice of the receiver depends on the accuracy you need, and your budget, of course. I can not know the prices in UK, you have to ask the local dealers of the companies, but a receiver with OS is surely more expensive.
stefanstamenov
I think ESRI work with Trimble, but I can not afford Trimble myself.
stefanstamenov
I hope gave some answer to your question.
