Customizing locator
2591
5
01-31-2013 05:41 AM
SunilKelkar
I need to modify US Dual range address locator to use one of the column in the reference data. I should be able to seach address using value from this column. Does any body has any sample style to perform this operation.
YuriyTsup
I need to modify US Address -Single House address locator style to use in the search for first street name, and then house number. For example: st. Madison, 320
What changes should I do in the xml file?
BruceHarold
Esri Frequent Contributor
Hi
Try this:
Look for the NormalAddress element, this is under the Top level elements.
Add an alt like this:
          <alt>
            <elt ref="FullStreetName" weight="60" separator_list=".,;-"/>
            <elt ref="House" weight="50" pre_separator="required"/>
            <elt ref="OptionalUnit" weight="0"/>
          </alt>
Regards
YuriyTsup
Thanks for the answer, but I'm probably doing something wrong, because I have a locator becomes inoperative. If you can, tell me
specifically where to insert this piece of code.
Best regards,
BruceHarold
Hi
NormalAddress is under the Top level Elements section.
Regards
YuriyTsup
Thank you, Bruce
