Creating Replica in 10.3
4251
08-20-2015 12:12 AM
AletyAnanda_Raju
I had created a batch file for creating and executing a python script which shall create a check out replica for the datasets in 10.2.2
Recently we have upgraded to 10.3 and due to this these batch files don't work. However if I try to create a check out replica manually, there are no issues.
What changes are done 10.3 that the previous versions of batch file will not work ?
What needs to be fixed to get it going ?
Regards,
Alety.
AletyAnanda_Raju
Resolved the issue by handling the "/" character.
RobertScheitlin__GISP
Alety,
   I had the same issue. I was using a bat file launched by SQL Server Agent to run my python script and once upgrading to 10.3 it no longer functioned. So I just changed to using Task Manager and calling the Python script directly. So I am not sure what changed but the workaround is simple and painless to implement.
AletyAnanda_Raju
Thanks Robert. But I don't use any scheduler. I execute this batch file as and when required. So still my question remains as what needs to be fixed at my end.
Alety,
   Are you sure that you have the correct path in your bat file to your Python exe? It changed in 10.3.
AletyAnanda_Raju
Yes the path is right since I use the same batch file by changing the connection pointing to the older one and it works fine.
AletyAnanda_Raju
