Create grid of points with arbitrary coordinate system, add elevation data to points
2481
08-11-2012 01:29 PM
BlairCampbell
Hi all,
I have a 2 sq metre microscale hydraulic model of a river, and have been using a laser rangefinder to detect elevation changes on an overhead rail, every 5 cm east/west and 5 cm north/south (a grid of elevation spot heights).
Is there a way to represent these spot heights as point data with elevation values; effectively creating a coarse raster in ArcMap?
How can an arbitrary coordinate system be assigned to these points, so they are in positions relative to reality? (through scaling)
Sorry for all of the questions, I am by no means a GIS expert, but can figure it out if guided to relevant help topics.
PavanYadav
First, I would like to know in what type of data file you are storing the elevation information in; is it a shapefile (gis data), or maybe a CAD file? If so, you can use the Spatial Adjustment tools to locate your non-gereferenced data to correct spatial location. Next, you could use the Point to Raster tool to create a raster. If you want a coarse resolution, you can use the Resampe tool. If the points are randomly distributed you may want to consider interpolate a surface. If you have a raster surface that does know where on the earth it is suppose to be, you can use the Georeferencing tools. For spatial adjustment, you may want to refer this Spatial adjustment tutorial.
Pavan
Pavan Yadav
Product Engineer at Esri
AI for Imagery
Connect with me on LinkedIn!
Contact Esri Support Services
BlairCampbell
Thankyou for your reply Pavan!
The elevation data are stored in a spreadsheet. I might need to explain the setup further.
I have a 2 m wide by 5 m long tilted 'table', with water and sediment feeders at the upstream end, and polystyrene inserts representing landforms/river channel boundaries. At the downstream end, water is re-circulated to a header tank.
This microscale model is scaled 1:5000 from its prototype river, thus is geometrically similar. To measure elevation, I have a steel bar with supports that is positioned horizontally over the model; attached to it is a builders laser rangefinder pointed towards the sediment.
I move the rangefinder in east/west directions every 5 cm for elevation transects, then move steel bar 5 cm south, and repeat another transect. Thus I have elevation points (e.g. 30.1 cm, distance from rangefinder from sediment). As the riverbed aggrades, the next measurement at the same point will be (e.g. 29.5 cm) to the sediment.
In the Excel spreadsheet, I have this grid of elevation points, and I am visualising that in ArcMap there might be a way to create a 'raster' of point feature classes, with a coordinate system (based on the model scale) that matches an elevation point to the corresponding position in reality.
Can it be done? I appreciate everyone's time or interest.
Blair.
JeffreySwain
So you have a series of points, collected at 5 cm increments and are looking to create a raster?  You could try a Spline to interpolate between the points, or if you have 3d Analyst you could create a TIN or Terrain to visualize it.  Each would create a continuous surface.  I suggested the Spline to rubbersheet and maintain the heights at the point.  Does that help?  It might also be interesting to convert the points to 3d and visualize in ArcScene to see if there are any issues with the data prior to interpolation.
iuriherzfeld
Hi.  I have a somewhate related question
I need to make an airplane approximation surface.  For this I need to make the polygon vertices be at different heights (not bound to any known surface).  Do not seem to be able to do this in ArcGIS.  I am sure in CAD this would be really simple.  Help please as I am not a CAD user.
