Copy row tool not copying all the values
1230
03-21-2017 11:33 AM
thomasricard
Hi everyone,
I need to geocode points and they come into a txt file. When using model builder i first create a table using the "Copy Row" tool. However only 10% (6,500) values are copied the rest is just gone. How can avoid this issue? Why aren't all the values being copied?
Any help would be extremely welcome.
Thomas
DanPatterson_Retired
Where and in what format are you saving it to? and is that particular record got any problems?
The output table can be saved in a dBASE, geodatabase, or a tab delimited .txt file.
thomasricard
Thanks Dan. I figured out that the .txt file was corrupted. I should have I looked at the source from the start and not insisting that the process was not working. Thanks again
