Converting Multiple Raster Files to Polygon
8445
5
09-08-2011 01:24 PM
SaraErickson
This is probably pretty simple to do, but I'm new to this process! I was wondering how you convert multiple raster files to polygons! I am able to process one at a time using "raster to polygon" under conversion tools in arctoolbox, but I have hundreds of files to do this to! Any help is appreciated!
EricRice
Esri Alum
Greetings,
You can make a model in model builder using Raster to Polygon and the Iterate Raster tool.
If you are uncomfortable with model builder, you can always right click on any geoprocessing tool and select 'Batch' to run the tool in batch mode.  This may help get you started.
A quick tour of batch processing
Best Regards,
Eric
SaraErickson
Thank you!!
FlorianRenner
I have the same issue with a set of more than 200 raster features stored in a GDB. I already created a model with an iterator but when I start it I get the message:
Failed to execute. Parameters are not valid.
ERROR 000864: Input raster: The input is not within the defined domain.
ERROR 000367: Invalid GP data type
ERROR 000864: Field: The input is not within the defined domain.
ERROR 000889: Invalid field type.
Failed to execute (Raster to Polygon).
Failed at Tue Nov 05 14:40:11 2013 (Elapsed Time: 0,00 seconds)
Failed to execute (Model12).
Failed at Tue Nov 05 14:40:11 2013 (Elapsed Time: 3,00 seconds)
Any idea what I have done wrong?
Regards,
FR
EricRice
Esri Alum
Hi Florian,
I suspect your raster data is 32 bit floating point.  I get the same message if I put floating point raster data into Raster to Polygon.  The tool only takes integer raster data as input.
Best,
Eric
FlorianRenner
Hi Eric,
thanks for your response.
Yes, I realized in the meantime that some of the rasters within the folder contained floating point numbers. I modified the model by inserting an INT task so I was able to run it successfully.
Best Regards,
Florian
